How much oil does a tranny hold
How much does a tranny hold. I have about 1.5 quarts if synthetic motor oil in it. I was told the tranny can hold almost another quart.
Its a 91 acura interga tranny on my b16..
Re: How much oil does a tranny hold (MIGPA26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIGPA26 »</TD></TR><TR><TD CLASS="quote">How much does a tranny hold. I have about 1.5 quarts if synthetic motor oil in it. I was told the tranny can hold almost another quart.
Its a 91 acura interga tranny on my b16..</TD></TR></TABLE>B-series transmission - 2.4 quarts for rebuild - 2.3 quarts for oil change
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIGPA26 »</TD></TR><TR><TD CLASS="quote"> I have about 1.5 quarts if synthetic motor oil in it.</TD></TR></TABLE>
i would not suggest synthetic motor oil. use honda MTF. its got the right additives for a transmission an engine oil wouldnt have. and sythetic actually doesnt work well with sycnhros, from what i heard.
either way, just use honda MTF.
Re: How much oil does a tranny hold (Tyson)
i was told to use synthetic motor oil. I have about 1.5 quarts in there and need to add a quart sometime my 5th gear gives me problems and thought of that
Re: How much oil does a tranny hold (jaywongwong)
Why instead of guessing do you not just go buy a bit more than needed, pull the overfull bolt out and top it up to exactly where it should be instead?
1 Post
Go buy 1 qt of penzoil synchromesh 2 gt of regular 10w30 and put all the synchromesh in, then add 1qt of oil, then add half of the other oil.
Now you be shifting with the butterness.
