how many dash bolts
Re: how many dash bolts (crxhftosi)
There is 4 main ones and I think 2 other ones. The main ones are: one is on the dash near the window center of the car has a little trap door you need to flip up and I think its a 10mm. Then there is one under the console where the metal frame of the console is bolted down to the chasis. Then there is One on each side of the vents where it sends air thourh ur air conditioning and heatind to the door panels. You will see it once you open your doors. You can see in the vents also and see them. There is another one near the fuse box under the dash I believe. Then there should be another behind the glove box on the right one of the big bolts. And if there is another It must be the bent tubing that is connected to the floor under the center console. Its been a while...but i think that is it hope this helps
B_Something
12-29-2007 09:07 AM
94CRVtec
07-22-2004 01:19 AM
Erik_Pb_Foot
12-29-2003 06:14 PM
