how do i test fan motor?
Old 05-02-2009, 11:09 AM
chieftaco's Avatar
Default how do i test fan motor?
my car is having fan trouble. after searching some threads i read that i should first see if the fan motor itself is by "jumping" the fan. How do i jump the 2 pin connector? I have the connector diconnected and tried to jump it to the battery but im not sure if I did it the correct way. thanks in advance
Old 05-02-2009, 11:24 AM
BoostedZC's Avatar
Default Re: how do i test fan motor?
12v to one side and ground the other i dont think you can do it backwards the fan will just turn the other way but its probably the collant temp sensor i have never had one that worked for the life of the car i owned it always had to rig the fan up on a switch or ignition good luck
Bldg1023
04-09-2017 04:34 PM
jlowellintegra
05-30-2011 07:52 AM
zeb1117
04-03-2010 09:33 PM
JDM_is_overrated
05-19-2008 07:56 AM
Doh!
07-03-2006 09:29 PM
Quick Reply: how do i test fan motor?
