Help identifying engine - JDM D15b?
Old 02-11-2014, 04:51 PM
primetime09's Avatar
Default Help identifying engine - JDM D15b?
I was told this was the jdm D15b and was hoping someone could confirm it. I am curious which parts will and won't fit on this engine, when I go to do simple things such as change the oil will it be a specific filter or will the regular 1990 civic filter work? Any help is appreciated as I am in the process of getting this car rebuilt and could use some help on what parts will fit. Image posted below, thanks.
http://postimg.org/image/n6fr24zy5/
Old 02-11-2014, 05:47 PM
Spug's Avatar
Default Re: Help identifying engine
What does the stamp on the front of the block say?
It's right on the left side of the block next to the transmission. It's a flat spot with the engine code stamped on it.
Old 02-11-2014, 05:57 PM
Unfortunately I can't get to the car right now as it is covered in snow.
Old 02-11-2014, 06:06 PM
Spug's Avatar
Snow sucks.
Well, when you get a chance to look, if there's a number at the end of the engine code, it's not JDM.
Old 02-12-2014, 04:22 PM
Thanks for the responses. Can anyone else help out?
Old 02-12-2014, 04:55 PM
lazlong's Avatar
Old 02-12-2014, 05:15 PM
instrument's Avatar
no one is going to "help out" youre going to lift your hood and read the engine code off the block and answe your own question.
there are too many combinations of these motors and people swap various parts onto diff blocks etc.
Old 02-12-2014, 07:55 PM
Glowicki's Avatar
You're pointing to the correct spot. Clean it off with a rag and degreaser and you will have your answer.
Old 02-13-2014, 04:06 AM
Freemananana's Avatar
It's a MPFI SOHC VTEC motor. That's for sure. There is only a handful of them. (D15B, D16Z6, D16Y8) You will have to check it out. It is impossible to tell.
Last edited by Former User; 02-13-2014 at 11:57 AM. Reason: Thread clean up - off topic remark removed.
Old 02-13-2014, 10:33 AM
Keyboard Humorist
4drEF's Avatar
Actually, the block could be just about anything and the head on it may be a vtec head.
Just pointing that out.
Block number will let you know what the bottom end is.
Old 02-13-2014, 11:52 AM
Graham Dunbar's Avatar
Dat heat wrapped rad hose
DonMizzi
10-30-2014 09:46 PM
97civicgirl
02-23-2011 08:00 PM
randommiker
04-27-2007 07:55 PM
kgoner45
11-27-2006 09:23 AM
Quick Reply: Help identifying engine - JDM D15b?
