HELP I am tryiing to replace the heater blower in my 91 Civic
I am trying to remove the heater blower in my 91 Civic and can not get the motor out. I have taken the dash apart with no success. The motor is loose by cannot remove it.
HELP Please
HELP Please
Re: HELP I am tryiing to replace the heater blower in my 91 Civic
Trying to remove the entire blower unit, or are you just wanting to pull the motor? The motor comes out of the housing with just 3 screws on the bottom. Pull the 3x 8mm bolts and 1x 10mm bolts that hold the glove box in, and you should have plenty of access to get the motor out without pulling the dash...may not even need to pull the glove box, I'm not sure. If you want the entire blower unit out, it is easier with the dash out, because you can then get the dash mounting bracket out of the way
I think you need to pull the glove box and the bar it bolts to, or at least it's easier, no need to remove the rest of the dash.
jester
11
05-18-2003 12:09 PM
