Fresh ZC swap, blowing fuse
Old 04-15-2006, 01:42 PM
D-Atk's Avatar
Default Fresh ZC swap, blowing fuse
Ok I just completed my ZC swap lastnight, went to start the car and sparks flew from the ground for the motor. No biggie we just moved it from its normal location, since then everytime I turn on the headlights the fuse for the dash and tail lights blows fuse #8. WTF is there a wire crossed somewhere? Car has been converted to OBD 1 but didn't have this problem till the swap.
Old 04-15-2006, 02:28 PM
civiccrx21's Avatar
Default Re: Fresh ZC swap, blowing fuse (D-Atk)
sounds like you could have the ground and hot mixed up or just the hot making contact with metal causing it to blow the fuse , bad bulbs can also blow fuses well at least on AC electrical.
I would go through the harness check to make sure all the wires are protected, take the bulbs out see if it still blows , otherwise bust out the Helms or chiltons wiring diagram and go over everything good luck
Old 04-17-2006, 04:53 PM
D-Atk's Avatar
Default Re: Fresh ZC swap, blowing fuse (civiccrx21)
Still no luck, we completely removed everything on the a/c side of the wiring and we got the dash lights to come on for a split second before the fuse blew. Anyone else got any suggestions.
-Racer X-
06-30-2013 04:56 PM
allenlavoie
04-23-2012 03:34 AM
killa69er
02-02-2011 07:00 AM
queda
05-23-2008 08:42 AM
2camsaam
03-12-2003 03:55 AM
Quick Reply: Fresh ZC swap, blowing fuse
