engine problems
engine problems
i posted b4, when i got this used car and explained wat was wrong with it....
ok, i fixed up everything i could.... and replaced many parts... but my engine still shakes and vibrates like a ****.
-i took care of the leaking oil... it was from the valve cover (replaced gasket, and sparkplug gaskets)
-i reaplced all 4 plug wires cuz one of them wasnt working..(only 3 clyinders were working)
-i got the dist. rotor replaced.
-i got new spark plugs.
-new air cleaner
-even cleaned out the TB
-used injector cleaner fluid
BUT STILL MY CAR IS A VIBRATING ****
i spent so much time, but i still cant get it to run "quietly and smooooothly"
it vibrates the most when depressing the brake pedal (coming towards a stop light)
please help !
-new air cleaner
please help !
Re: engine problems (kim_2_da_chee)
please help !
[/QUOTE]
Cut your rotors!!!!!!!!!
please help !
[/QUOTE]
This might be a long shot but It is a possibility...You said that I spent so much time, but i still cant get it to run "quietly and smooooothly"
please help !
[/QUOTE]
By cutting your rotors I mean sometimes the rotors for your brakes get rusted and all shitted up witch makes the car feel like its viberating....If you have them cut the problem goes away
Re: engine problems (ngkplugs)
What he means by "cut" (at least I hope so) is to have the front rotors resurfaced or turned. Also I would highly recommend inspecting all motor mounts also.
Zendos
11-04-2009 04:02 PM
turboteg90
10
09-19-2008 01:06 PM
