engine harness and interior harness: crx and ef hatch interchangeable?
#26
Re: engine harness and interior harness: crx and ef hatch interchangeable?
so if i i hav a 90 crx hf. i need a 90 crx hf full harness. and if i have a full 88 civic dx swap i need a 88 civic engine harness and jus tap into the stock engine harness. but wont it be difficult to tap the harness since a crx is mpfi and a 88 civic is dpfi and theres alot of stuff different?
#27
you will need the 1988 civic DX harness FOR PARTS(wires/connectors) but you will keep your 1990 crx HF harness and modify that one(add the wires/connectors from the 1988 DX swap's harness)
just know that WHATEVER swap you wanna do to you crx HF you will need to modify your engine harness for that specific engine but you NEED to remain with your HF engine harness(just modififed for whatever swap)
theres couple people that have done this for better gas mileage check it out on google or on the FAQs maybe...
#28
^^^thanks bro. well i kinda did it as a temp. but idk maybe the mpg might make me wanna keep it. i need to track down a hf harness than
#29
#30
you know wat the crazy thing is...no that i did my swap i seee quite a bit of crx's for sale with this swap!?!?! crxs didnt come with this motor right!!!
#31
#34
i have a 91 si harness int and ext on my 89 std theres certain things you have to change
#35
i just picked up a complete si harness for my dx. not much changes. just little plugs here and there.
#37
What plugs did u change cuz my car never came with a cabin harness or atleast not there when I got the shell but I have a si hatch interior an exterior harness will it work...I need help
#38
They are the same as long as you get the right year.i tried to use a 90 ef hatch under dash harness on my 89 crx hf.some of the plugs are different on the fuse box plug.if yours is a 90.use a 90/91 harness.
thorclark
04-29-2008 07:39 PM
McLovin
04-25-2008 09:57 AM
