engine bay fuse panel: whats the white wire for??
Old 05-02-2006, 08:48 AM
hatchinprogress's Avatar
Default engine bay fuse panel: whats the white wire for??
im doing an obd-1 conversion in my crx (got harness from ry-wire) well my e.b. fuse panel was relocated to under the glove box (by previous owner). well i got every thing plugged in except the solid white wire (it has an "eye let"...almost like it would be a ground) it wont reach the fuse box so i need to know: is it a ground wire?? (i dont think so, because it's solid white) and if not could i just extend it? or will that cause any resistance problems? thanks for any help
Old 05-02-2006, 09:03 AM
89crxhf's Avatar
Default Re: engine bay fuse panel: whats the white wire for?? (hatchinprogress)
i relocated that fuse box also, it probally goes to the lower left corner of the box. there are 2 wires that go there both have eyelets to srew them down. pics would help alot in figureing out were they go.
Old 05-02-2006, 09:48 AM
wood 1's Avatar
Goes beside the white / red wire.
Old 05-02-2006, 10:36 AM
Default Re: engine bay fuse panel: whats the white wire for?? (89crxhf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89crxhf &raquo;</TD></TR><TR><TD CLASS="quote">i relocated that fuse box also, it probally goes to the lower left corner of the box. there are 2 wires that go there both have eyelets to srew them down. pics would help alot in figureing out were they go. </TD></TR></TABLE> it does go to the lower left of the box, the wire i need is a solid white wire. the wire is comming from the engine bay wire harness(right next to the "power plugs") ill work on finding some pics <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wood 1 &raquo;</TD></TR><TR><TD CLASS="quote">Goes beside the white / red wire.</TD></TR></TABLE>but what is it for?? is it a ground? can i extend it?.....
Old 05-02-2006, 10:52 AM
wood 1's Avatar
It is not a ground, and yes you can extend it.
My 93 accord
09-29-2016 11:20 AM
BoorishId
06-25-2009 04:55 AM
(760)doogie
07-09-2007 04:20 PM
HondaHemi
11-27-2006 04:38 PM
JapJunkie
Welding / Fabrication
11
06-09-2006 02:06 PM
Quick Reply: engine bay fuse panel: whats the white wire for??
