Does a MPFI swap getting better gas mileage then a DPFI?
Old 09-19-2005, 11:50 AM
vtecn8ive's Avatar
Default Does a MPFI swap getting better gas mileage then a DPFI?
Now I am talking about a swap not the stock Si, EX or HF models.
I have a d15b2 that I would like to convert to MPFI but this car is my gas hugger . I dont' want to do the swap and have it eat up my gas. I would be use a pm6 ecu (crx si), 92-95 dx intake manifold with injectors (i'm aware of the obd1 factor), and crx si dizzy (if needed). Sound about right?
I am getting about 35 mpg right now on my STD model but I gun it all around as is. so i am sure it can get slightly better.
-Shane
Old 09-19-2005, 12:20 PM
DaX
DaX's Avatar
I say don't change a good thing. Both my Civic's are DPFI right now, and I'm leaving it that way because my STD gets about 32 mpg and my DX gets about 36 mpg.
If mileage is your #1 factor, the only way I'd go MPFI is if you do the entire HF setup, which wouldn't be worth it IMO.
If you're getting 35 mpg with your setup, no need to change!
Old 09-19-2005, 12:28 PM
Needs to be About 20% Cooler
DieMaster's Avatar
Default Re: (DaX)
i was getting 20-21 mpg on dpfi and now i'm getting 38.4 on mpfi
Old 09-19-2005, 02:36 PM
Mr.Quang's Avatar
Default Re: Does a MPFI swap getting better gas mileage then a DPFI? (vtecn8ive)
35mpg DPFI
32mpg MPFI
Both with the 4 speed manual and an hour of city driving to day to work
Old 09-19-2005, 03:43 PM
bspeed's Avatar
Default Re: Does a MPFI swap getting better gas mileage then a DPFI? (Mr.Quang)
the BIGGEST change will occur after you convert to MPFI OBD-1 from non-OBD, the four wire O2 and higher resolution maps including injector shut-off when you coast downhill in gear.
gnxpro24
32
09-07-2011 05:41 PM
crxhf15
02-01-2008 04:34 AM
liquidoblivion
10
07-20-2007 09:28 PM
d16y8crx
10-18-2004 12:33 PM
phoboyjimmy
11
11-13-2002 07:48 PM
Quick Reply: Does a MPFI swap getting better gas mileage then a DPFI?
