d16y8 in a 90 ef hatch
Old 04-14-2012, 03:41 PM
JustHonda2's Avatar
Default d16y8 in a 90 ef hatch
I just put a 96 d16y8 in my dpfi 1990 hatch, i used a do it yourself boomslang harness. Everthing works and it idles fine but when i rev it un nutral or driving it, it rev limets at 4k no matter what (im using a p28) please any ideas???
Old 04-14-2012, 03:45 PM
lazy14's Avatar
Default Re: d16y8 in a 90 ef hatch
is it a automatic ecu?
Old 04-14-2012, 04:24 PM
JustHonda2's Avatar
Dot think it is looks like a manual do they liok like the same case?
Old 04-14-2012, 04:29 PM
sirtef9's Avatar
CEL's?
Old 04-14-2012, 06:38 PM
JustHonda2's Avatar
actually didn't think they would be accurate im useind obd1 inj and obd2 dizzy and obd alternator, any ideas people?
Old 04-14-2012, 07:01 PM
JustHonda2's Avatar
ttt anyone
Old 04-14-2012, 07:07 PM
titosek4's Avatar
Couple of friends of mine had a similar issues, turned out to be the o2. One was running a one wire o2 and needed a four wire. Other friend of mine had a fuel delivery issue, might be worth looking into let us know what your end result is
Old 04-14-2012, 07:21 PM
JustHonda2's Avatar
well my be no i ran a 4 wire o2 and fuel is fine, how bout dizzy? i have heard so much bs from people lol just give me the answers lol its my dd
Old 04-14-2012, 07:38 PM
Nickeg9Ej1's Avatar
no cels? stock p28 no chip or anything?? on the last three numbers of your ecu part number should say -A_1 if the blank is a 5 its a auto and if its a 0 ifs a manual
Old 04-14-2012, 07:47 PM
JustHonda2's Avatar
and if its auto?
Old 04-14-2012, 07:48 PM
JustHonda2's Avatar
and i do have a check engine light on but i have no air intake sensor on mani or iac cause its a auto mani
Old 04-14-2012, 07:56 PM
Nickeg9Ej1's Avatar
I've been told depending on the version of the ecu some auto's wont allow your to rev past a certain rpm if it thinks its in park.
Old 04-14-2012, 08:06 PM
JustHonda2's Avatar
that woul suck lol
Old 04-14-2012, 08:11 PM
JustHonda2's Avatar
so any other idea? i wanna try them all
Old 04-14-2012, 08:15 PM
Nickeg9Ej1's Avatar
yeah it would, besides that Id triple check the dizzy wiring, and fix whats you know is missing
Old 04-14-2012, 08:18 PM
JustHonda2's Avatar
ok thanks
Old 04-20-2012, 04:12 PM
JustHonda2's Avatar
ttt
Old 04-20-2012, 04:13 PM
JustHonda2's Avatar
ok my cels were injector ecu and iac(which waas unplugged) i tried 3 different ecu's still wont rev over 4000 please help could be wiring harness lol stupid boomslang harness
Old 04-20-2012, 04:24 PM
Keyboard Humorist
4drEF's Avatar
IAC is now hooked up?
Figure out what the injector issue was? (that might be the problem there - might be in limp mode).
Seems you wrote "ecu" as a cel as well??
What is the code numbers you were getting?
Old 04-20-2012, 05:16 PM
JustHonda2's Avatar
9 14 and something else iac was on but ive tried reving with iac hooked up to
Old 04-20-2012, 05:30 PM
EF_90_HB's Avatar
hey all . i have a 90 EF with a dpfi and would like to convert to mpfi . is this an easy swap ? has anybody done it . because i am aware that this car was made only for fuel economy but i would like to make a little faster . and my plans are throttle body, intake manifold, intake and headers . but i was told that with the dpfi it wont add much if any HP with these without the swap.
Old 04-20-2012, 05:31 PM
Keyboard Humorist
4drEF's Avatar
Hook everything up.
Disconnect ECU for a few minutes (to clear all codes).
Reconnect ECU and try it again.
Check for CEL and post all the numbers you get.
Old 04-20-2012, 05:36 PM
EF_90_HB's Avatar
thanks . i mean will the mpfi make any difference?
Old 04-20-2012, 05:47 PM
JustHonda2's Avatar
Originally Posted by 4drEF
Hook everything up.
i will tomorrow any idea off top of your head though? i think its the boomslang harness
Old 04-20-2012, 05:49 PM
JustHonda2's Avatar
yes it will especially with aftermarket intake or a d16y8 manifold not a 99-00 on though it will not work
FRKWOO
08-01-2009 04:59 PM
the_crowbar
08-30-2004 09:38 AM
groundedcivic91
01-26-2004 09:08 AM
SprayinCX
04-12-2003 08:45 AM
Quick Reply: d16y8 in a 90 ef hatch
