crx fuel pump not turning on
Old 10-22-2007, 02:30 PM
crxsleeper210's Avatar
Default crx fuel pump not turning on
ok after i removed my hatch from the body i cut the wires that go to the wiper motor because i will be using an CF hatch. I also unbolted the 2 grounds i believe that are on the hatch itself. Now my fuel pumo isnt turning on for some reason. Would removing the hatch affect the fuel pump in any way??. Its a brand new walbro that ive had for 2 months never gave me a problem whatsoever. Usually i can hear it come on when i turn the key but now its not.
Old 10-22-2007, 03:24 PM
Crx Jimmy's Avatar
Default Re: (Dustin_Pierce)
try hooking those grounds back up. also check at the plug, see if the harness is grounded. if so then hook up 12v directly to the wire and see if it turns on.
Old 10-22-2007, 03:45 PM
Default Re: (Crx Jimmy)
yes the pump is installed correctly and i will try that jimmy thx
Old 10-22-2007, 03:57 PM
welfarepc's Avatar
sounds easier to just use a volt meter... GL
cleo7
01-23-2013 08:53 AM
Xplicitz
02-06-2010 03:13 PM
93formula
01-11-2007 03:14 PM
92redhatch
12
08-09-2006 08:23 PM
DsMWookie
10-21-2003 10:19 AM
Quick Reply: crx fuel pump not turning on
