Clutch wont disengage - tried everything
#26
Re: Clutch wont disengage - tried everything
So you had to adjust it so the nut is almost at the bottom of the cable, taking up a lot of slack?
#27
Any idea how much space is needed on either side of the clutch disc to disengage? Right now looking through the starter hole it looks like there's about 3/4mm on either side (with the clutch pushed in).
#30
Well, I adjusted the clutch cable so there's 3-4mm play at the end, I can get a full pedal press without maxing out the release arm travel so I think it might work.
zerovandez
03-10-2007 11:08 AM
