I have a bit of a messy situation, I have a few rusted fuel lines, where as one of them are leaking pretty bad. I'm not quite sure which line this is, but its an 8mm hardline. What would the easiest fix for this be? And what kind of line is this, is it the return?
It's the fuel feed line that gets pressurized.
If you do find a used line to replace it with, the round 90deg connector is different thread size I heard from the '88 vs '89-91..
I just had this same issue. Unfortunately, that line is discontinued. I cut that connection out, got a 3/8" fuel injector hose and straight lined it. On the larger metal line, I had to use a lube and force it on. I then heated the hose and pushed it the rest of the way on to a secure position. Put some hose clamps on each end and it held fine. I've been driving it a week without any issues.
