Cable to Hydro
Old 10-19-2011, 09:36 AM
EF8DayDreamer's Avatar
Default Cable to Hydro
Building a LsV. Gsr Head, Ls Block, was thinking about b16 tranny but i know they can't hold much HP before the differential **** the bed. so im just gonna convert to hydro so i can use a gsr tranny. i dont know what kit to use and what to get to complete this correctly.
Old 10-19-2011, 09:44 AM
judgeDredd's Avatar
Default Re: Cable to Hydro
complete kits available
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/hush-performance-hydro-conversion-v2-5-a-2939583/
http://www.facebook.com/#!/pages/Hus...65426303519234
Old 10-19-2011, 11:11 AM
cesf2006's Avatar
http://www.suja1motoring.com/product...px?productId=1 this kit worked the best for me....
Old 10-19-2011, 11:25 AM
most_hated_crx's Avatar
I have hassport's kit. has worked great for me!
Old 10-19-2011, 05:06 PM
spank88's Avatar
this is the way to go
Old 10-19-2011, 05:34 PM
judgeDredd's Avatar
I have used all 3 kits listed here i can tell you that with out a doubt the Hush kit is the best.
The hasport kit is a joke and still uses a cable.
The sonem is a good piece for when it came out and it was the only option, i used it for about 2 years or so.
The sonem piece is not a bolt on like the hush kit, it does require welding the design is simple with little reinforcement when i used to press the clutch pedal my whole pedal assembly would flex. With the hush kit i have a solid pedal feel with no flex.
You can order the hush kit with just the bracket or you can get the complete change over package. Bisimoto is currently running the hush kit on his 700hp wago as our several others.
there are plenty of photos and videos on the facebook page to show how everything works.
Old 10-19-2011, 10:47 PM
EL Vap133's Avatar
So no links judgeDredd??
Old 10-20-2011, 03:37 AM
0x5359-0055
213374U's Avatar
5 posts up haas
As Dredd said, the sonem-styled kit has flex. I'm running it in mine now but fabbed my own supports to make it solid, and I love it. Any of the Hasport styles are garbage, simply a way to use the hydro tranny the lazy way. With the sonem or hush kits, the only things you'll need in addition are the master cylinder, fluid reservoir, and a couple lengths of hard-line that you can pick up at vatozone.
Check my build thread if you're at all interested in the install process. Pretty sure I documented and took pics when I did mine. Good luck
Old 10-20-2011, 06:05 AM
hush22's Avatar
Not true with the Hush Performance kit
YOU CAN GET EVRYTHING!
EF V2.5 CABLE TO HYDRO
DA CABLE TO HYDRO
OUR EF V2.5 will also accept the use of a Wilwood clutch master. A perfect upgrade when using Twin disc or dual diaphragm pressure plates.
Installed
You can see the more information on our Facebook page
https://www.facebook.com/pages/Hush-...65426303519234
Which ever route you take, the best of luck to you.
Old 10-20-2011, 06:28 AM
0x5359-0055
213374U's Avatar
Any difference in pedal feel between the braided line and factory hard lines?
Old 10-20-2011, 06:30 AM
judgeDredd's Avatar
i never had hard line but i can tell you theirs a difference in feel from -4 and -3 with -4 making it a little less stiff.
Old 10-20-2011, 06:32 AM
0x5359-0055
213374U's Avatar
Mine is pretty stiff and I'm running a factory clutch/pp. But to be honest, I like it the way it is. The reason I can't stand driving stick in trucks/suv's. More or less just worried about losing that stiffness.
allmotorh2b
35
03-17-2012 06:19 AM
Bc1r6x
05-18-2006 11:56 AM
shingles
04-16-2003 03:15 PM
Quick Reply: Cable to Hydro
