Brembo Brake Rotors - having problems now.
Anybody here have a set of Brembo cross-drilled stock-sized rotors on their 4th gen? I have had mine for over 9 months. I have had 2 different set's of Rota's on them, the SLIPS, and the C8's, have had the 99-00 SI stocks on them, then the 01 LS stocks. All fit perfectly fine, then I ended up with a set of 99GSR blades and I am having problem fitting the wheel onto the front driver side. It does not slide fully over the little groove that rises up on the rotor? I do not understand why it seems larger now. Would it be safe to grind it down so it doesn't even stick up? Any help is greatly appreciated. THanks
Re: Brembo Brake Rotors - having problems now. (jonGSR)
Are you absolutely certain about the rim. A minor problem with the clearances involved can do this. Do not machine the hub or rotor. Carefully inspect the hub and mating surface on the wheel. I have Brembo Blanks on the CRX with MR12's and no problems with either them or the stock Si wheels.
Re: Brembo Brake Rotors - having problems now. (jc836)
I'm positive, I even tried a 15" stock steel wheel and it would not fit. I can't imagine the LS or SI stocks being much different as to where the GSR wheel doesnt fit correctly.
mojoGSR92
05-28-2006 10:55 AM
allmotorEG-SI
12-12-2003 06:02 AM
