brakes
brakes
i changed the brake master cylinder/ booster on a civic sedan, i used integra parts and bled the system I have presure when the car is off but when its on i can hear air leaking and the pedal goes to the floor. does this mean that the booster is bad
Re: brakes
I just installed an EX m/c on my hatch, the m/c came with the nipples and tubing needed to bench bleed.
Basically, you thread nipples to the ports and attach fluid lines to them, then you run the lines back into the reservoir. Cycle the m/c piston with a screwdriver which drives the air out of the mc and into the reservoil where it floats out of the system.
Re: brakes
Since y'all talking about brakes any one know where I can get steel braided lines for my 90 hatch I broke the original ones changing the trailing arm bushings don't want to put the steel lines
