Blinking engine light problem
Old Aug 4, 2006 | 05:16 PM
Nay's Avatar
Nay
Default Blinking engine light problem
OK here is the deal. I was driving home normally at around 90kmh and the engine light started blinking. The light blinks 7 times than stops for a bit than 7 times again and again. The car seems to run fine. The car is an 88 civic hatch, b20b bottom, b16 head, OBD-1. If you know what it is please help.
Old Aug 4, 2006 | 06:10 PM
Mr_CRX's Avatar
Default Re: Blinking engine light problem (Nay)
You probably have the wire from D4 on your ECU harness grounded out. That's typically how you check the Check Engine Lights on OBD-1 converted cars. If this is the case, and you have that wire grounded out, you are throwing a code 7 which is the TPS (Throttle Position Sensor).
You can try resetting the ECU and seeing if it comes back or not. If it does, check the wiring nearby for any problems (it's a 3-wire sensor on the firewall-side of the throttle body) On the ECU side of the harness, the wires are:
Pin - Color
D11 - Red/Blk
D20 - Yel/Blu
D22 - Grn/Blu
Old Aug 4, 2006 | 06:19 PM
Nay's Avatar
Nay
Default Re: Blinking engine light problem (Mr_CRX)
thanks its dark but im goin to see if that works.
Old Aug 4, 2006 | 06:45 PM
Nay's Avatar
Nay
Well went for a drive and all seems well. Thanks H-T another problem solved, i hope.
Old Aug 4, 2006 | 06:51 PM
SVOboy's Avatar
If it's not you can just pop in another tps.
Old May 10, 2017 | 07:31 AM
CFFA17's Avatar
take it to orieleys and they can hook a computer up to your car and see what is wrong with it for free
Old May 10, 2017 | 11:05 AM
24TEN's Avatar
PHANTOM MENACE
Please visit the FAQ and rules section. You responded to a post from over a decade ago.
GsrRussell
Sep 24, 2008 08:32 AM
racingcrx
13
Sep 10, 2006 12:52 AM
MASTERJDM
May 14, 2006 11:38 AM
00ekhatch
Feb 10, 2005 11:58 AM
