ARP extended wheels stud's???
ok I have been thinking about buying some for my 91 hatch but my question is will they work with the rear drum brakes or would i have 2 convert them 2 disk's before I did it?
Thanks for any help
Justin
Thanks for any help
Justin
Re: ARP extended wheels stud's??? (aaronhume)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronhume »</TD></TR><TR><TD CLASS="quote">yes they will work.</TD></TR></TABLE>
yup, I just got done installing a set on my CRX DX. The rear drums are actually easier to do.
-remove rear tires
-release parking brake
-remove axle nut cover
-remove 32mm axle nut
-remove drum (might have to use two bolts if it wont budge)
-remove axle key under axle nut (large washer with a tab on the inside)
-remove hub (pull it off, or use a hub puller)
-press old studs out, press new studs in (if you need tips on how to do this let me know)
-install everything reverse of removal
If you are in there you might wanna repace the brake shoes. Each shoe is $15 from Honda so for a total of 4 it's $60 plus tax. I got mine for $36 out the door at Carquest. Also if the wheel bearings are bad you will have to buy a new one. The wheel bearings are built into the hub. So a new hub/bearing will cost $80-$100 each., but I just reused my old ones.
-remove rear tires
Joey.
07-05-2006 04:44 PM
