arp extended stud problem
Old 03-28-2009, 08:40 PM
m_shake's Avatar
Default arp extended stud problem
just installed my wheel studs and im having an issue with them. im running buddy club lug nuts and they are really hard to thread on, stock ones spin on fine and the buddy clubs were fine on the stock studs but no go on the arp's. i guess i could chase the thread on both the stud and the nuts but not to sure. oh and before some one says just use honda nuts, my wheels dont take to ball seat there taper. if anyone has had this issue and has a solution please let me know, thanks.
Old 03-28-2009, 08:51 PM
Disco Monkey's Avatar
Default Re: arp extended stud problem
my friend had the same problem with his work lug nuts and arp studs. i think he ended up chasing the thread on the lugs.
if you don't want to do that, you could get different lugs. my muteki lug nuts threaded on my arp studs just fine.
Old 03-28-2009, 08:56 PM
m_shake's Avatar
dude thanks for the info, hell i feel alot better know im not to only person who has run into this problem. gonna get a tap tomorrow and chase em out, thanks again bro!
Old 03-30-2009, 07:06 PM
EFhatchSi's Avatar
Hey i had that exact same problem with the same exact setup (arp studs/buddyclub lugs) i just used a die for the stud and tap for the lug.... worked great
Old 03-30-2009, 08:20 PM
DazeMS's Avatar
this is such crap.. why does this even happen in the first place? Someones manufacturing sucks *****
Old 03-30-2009, 08:27 PM
dr_latino999's Avatar
Are the lugs you are having issues with aluminum by chance?
Old 04-02-2009, 12:10 AM
88_acED6's Avatar
skunk2's dont have a prob with arp studs..my setup..my friend had buddy club lugs and he had to chase them almost everytime they were removed
Old 04-02-2009, 01:34 AM
spikehead221's Avatar
Location: Staring down the barrell of my 12 ga. Texas, USA
they only thing i would think of is if the lugs are softer than the studs, they may deform slightly... at discount tire, i had this issue every once in a while. i just ended up using anti seize lube and the gun to thread em on...
import-tooner
09-29-2012 03:23 PM
misha
04-25-2010 12:36 PM
bigBOI_92DA9
08-14-2005 08:03 PM
ActiveAero
12-04-2004 01:32 PM
Quick Reply: arp extended stud problem
