Flywheel question:D16A6 all rusted and stuff what should I do??
Old 11-27-2006, 04:33 AM
Xemu's Avatar
Default Flywheel question:D16A6 all rusted and stuff what should I do??
Just picked up a D16A6 Si motor and Si tranny yesterday for my minime boost set up.When I pulled the clutch I noticed the flywheel is rusted up pretty good.Should I swap it out for a lightened flywheel,resurface it (how much will that run me) or is it ok to run as is??? Thanks for helpin me out!! I cannot wait for boost!!!
Old 11-27-2006, 06:08 AM
Xemu's Avatar
Default Re: Flywheel question:D16A6 all rusted and stuff what should I do?? (Xemu)
Anybody???
Old 11-27-2006, 08:11 AM
peanut butter's Avatar
I'm interested too, I'd like to know how much it cost for a resurface or to have a couple lb shaved off the stock one vs an aftermarket flywheel.
Old 11-27-2006, 08:13 AM
92civicfreak's Avatar
i got mine shaved at a shop... $5-$15
Old 11-27-2006, 06:19 PM
Xemu's Avatar
So again is it ok to run it all rusted up???
Old 11-27-2006, 06:27 PM
Voodooboy520's Avatar
If you dont like your clutch. Just get it resurfaced.
Old 11-27-2006, 09:24 PM
Xemu's Avatar
Default Re: (Voodooboy520)
But can I run it rusted will it create problems???
Old 11-27-2006, 09:26 PM
civiconfire's Avatar
i wouldnt, its too much work to pull the tranny off because you didnt want to spend a few dollars to get it resurfaced.
might as well see if you can get it lightend a few pounds while your at it.
Old 11-27-2006, 09:29 PM
downest's Avatar
Default Re: Flywheel question:D16A6 all rusted and stuff what should I do?? (civiconfire)
Hey man, I live right near you (Durham) and I have a few CRX flywheels kicking around...
Old 11-27-2006, 10:12 PM
downest's Avatar
Sorry, to answer your question, if it's rusted you should at least resurface it.
Old 11-27-2006, 11:44 PM
Nerologic's Avatar
i have ran em rusted...
they end up getting "re-surfaced" by the clutch anyway...
it might waste the clutch slighlty more then normal, but thats it i had no issues with it...
Old 11-27-2006, 11:48 PM
JT2MA71's Avatar
If it's light rust, go over it with emery cloth on a block.. If it takes effort to remove it, get it resurfaced.
Old 11-28-2006, 08:04 AM
KansasKev's Avatar
Does resurfacing and lightening the flywheel increase horsepower? Or just enable the motor to rev up and down faster?
Old 11-28-2006, 02:45 PM
Nerologic's Avatar
Default Re: (KansasKev)
lets the motor rev faster (less mass spinning) and u have less drivetrain power loss = a tad more power to the ground...
Old 11-28-2006, 04:14 PM
d16vtecx's Avatar
Default Re: (Nerologic)
its only like 30 ucks to get it resurfaced and its cheap insurance
Old 11-30-2006, 05:13 AM
Xemu's Avatar
Default Re: (d16vtecx)
I may just buy a lightened one,any idea how light you can go before having to cross your fingers.Because I have heard of them being to light and shattering.This will be eventually a boosted motor so is it safe to run a lightened flywheel boosted???
Old 11-30-2006, 05:29 AM
something different
redzcstandardhatch's Avatar
its safe, but i'm a fan of stockers.
i ran a LIGHT one (8 lbs i think) on my 300.08 hp/250 wtq a6.
took it off because i wanted the heavier factory one for driveability with a crazy clutch.
Old 11-30-2006, 08:37 AM
STREETWERKZ's Avatar
Default Re: (redzcstandardhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">its safe, but i'm a fan of stockers.
with that sort of power, no need for a lightened flywheel. i would have done the same.
for NA cars, i love lightened flywheels.
Old 11-30-2006, 09:04 AM
something different
Default Re: (STREETWERKZ)
absolutely.
Emorales
10-07-2009 07:14 AM
92_civic_lx
23
01-25-2009 12:32 PM
EFsSuck
01-06-2007 06:24 AM
drintegra
05-14-2006 04:35 PM
EvilIntegrationLS
12-17-2002 08:54 PM
Quick Reply: Flywheel question:D16A6 all rusted and stuff what should I do??
