91 Hatch Si Jumping Tach and slight stutter
#26
Re: 91 Hatch Si Jumping Tach and slight stutter
I've been thinking it's the air in the coolant loops issue because it didn't start until after I flushed and re-filled the system when I replaced the thermostat last weekend. I will try bleeding it again this weekend, just haven't had a chance to try again yet.
#27
i had the same problem with the jumping tach.. it ended up being the blue tach wire off of the dizzy where it went into the connectors. it was corroded!!
#28
#29
Just a little tip, for my 91 crx there was an ignitor TSB and it was replaced for FREE at the dealer when i had my seatbelts replaced.
#30
Heres an update on the problem.
I replaced the ignitor with a factory part. The car has a different problem now. Was on the frikin freeway the other day. Car was rippin right along as usual, but when I let off the throttle the car died. I've had a similar problem around town too. All I have to do is turn off the key and restart the motor and it starts every time, like a top.
Starting to think its my TPS. Going to run a test soon. Weather is crappy here now.
#31
Ok I have a 90 Crx, with B17 I'm having kinda the same issues. But where do u find the little bleeder valve on the B series? Is there one even On the b series? I've already cleaned my IACV, and adjusted my FITV. Nothing has changed. And when my car is runnin at normal operating temp it holds steady @ 2000rpm. Please help, it's really starting to annoy me
#32
I'm have the same problem except mi idle only jumps from 800-1000 and it bogs a little when its cold. Could it be the same problem ? I'm going to try changing my cap and rotor and see if that helps. Does anyone have any input ?
#33
http://www.youtube.com/watch?v=s6wYe...eature=related
Thats what i did, worked great. car now idles like it should.
sc300turbo
10
02-04-2005 12:13 PM
