91 crx b16 to gsr swap. HELP!!
ok so i had a b16a in my 91 crx si, i took it out about a year ago and started building a "poor man's type R" ( gsr block with b16 head.) now i finally finished it and am putting it in the car. problem is there are several things that are different on this block than the b16 block, 1st diff is that there are only 2 sensors on the back of this block knock sensor and oil pressure... therefore i have the two prong plug for the engine fan switch( the one with two separate wires that go to the same sensor) and a 1 prong connector left getting no love...
where do these plugs go on the gsr block?? am i missing sensors ( doesn't look possible) anyone have PICS of the back of a gsr block??
question 2: my engine has no oil cooler. im confused as to the routing of all the coolant hoses.. also where the heater hoses go( i am bypassing my TB and this mod was done on the b16 as well .. remember same head/intake mani, just diff block)
question 3: there is a two prong sensor that is directly on the thermostat housing of the gsr block that was not on the b16 block.. is it possible that the two prong( two separate prong for the engine fan switch) needs to be converted and extended to the regular two wire plug that is used for many other sensors on the vehicle?? i believe that is all for now. TIA for ANY help/ links
and trust me , i have searched like a mad man trying to figure this out.
Re: (ahthisguyhere)
is the sensor on the thermostat the same sensor as the one with 2 separate wires that is on the back of the block on the b16?? if so i would need to simply extend those wires and put that temp sensor plug on the end of the wires and plug that motha in..
918-Hatch
12-10-2006 05:28 PM
ScottEK
10-19-2003 02:20 PM
