89 EF Hatch Code 20 on ECU
Old Mar 1, 2011 | 07:15 PM
HondaMan2380's Avatar
Default 89 EF Hatch Code 20 on ECU
I recently bought myself an EF, but I am having a very weird electrical problem. I found the LED on the ECU flashing 20 times then pausing. Is there a way of figuring out what is putting such a load on my electrical system?
Old Mar 2, 2011 | 06:23 AM
dephtone's Avatar
Default Re: 89 EF Hatch Code 20 on ECU
Here is a way to troubleshoot Code 20.
Old Mar 2, 2011 | 07:06 AM
jlicrx's Avatar
what that ELD troubleshooting fails to address is before you suspect the ELD, you need to make sure that the alternator is good - over the years we have found that in almost all cases the Code 20 can be cured by installing a good alternator - the problem is not that something is overloading the circuit but rather that the alternator cannot provide the amperage that is required - usually a problem with the alternator diodes - aftermarket rebuilt alternators from Advance Auto, Autozone, etc. are garbage and installing one probably won't cure your problem - get a good Honda alternator - even used ones from a junkyard will last longer than one of the aftermarket rebuilt ones
Old Mar 3, 2011 | 06:31 PM
Thank you both for your advice. I will be able to troubleshoot it tomorrow. I really appreciate your help.
Throwback23
13
Feb 5, 2011 01:20 PM
Sportyballade
Oct 27, 2006 05:05 AM
hitvtecgetloud09
Nov 11, 2004 08:43 AM
mugenhatch92
Aug 31, 2004 06:51 PM
