5 pin blue gauge cluster plug
Old 09-07-2009, 12:41 PM
ketchup's Avatar
Default 5 pin blue gauge cluster plug
Someone said that it might be fore cruise control? I have a similar box on the back of my gauge cluster for my 91 HF and no one seems to know what it's for. The cluster does not have a shift light either.
In any event, does anyone have the pinout for it? I'd like to know what wire/pin is for what (ground - power - signal) so I can make some use out of it.
Old 09-07-2009, 12:44 PM
dragvixen's Avatar
Default Re: 5 pin blue gauge cluster plug
whats it to.
Old 09-07-2009, 12:48 PM
ketchup's Avatar
Originally Posted by dragvixen
whats it to.
Not sure exactly what you're asking but...
I've got a 5 pin plug on my dash harness that goes into that blue housing in that box on the back of the instrument cluster. 91 HF.
Old 09-07-2009, 12:51 PM
dragvixen's Avatar
sry ment what car it out of i see 91 HF
Old 09-07-2009, 01:05 PM
dacrxguy's Avatar
on the service manual it says that if is for "HF" only so i am in the conclusion that it is the sift light i. i have a dx auto and man cluster and both of these have it. i disconnected it once but did not notice nothing funny.
if you look real close you can see that one wire goes to the circuit board to the mph and a ground coming off the tach. it then goes to the circuit board that is inside
Old 09-07-2009, 01:08 PM
ketchup's Avatar
yea I figured it was for the shift light but this cluster doesn't have on but does have the box. I think since it's a 91 the cluster doesn't have it and the 88-89 cluster's have them.
Can you identify the wires? I want to use it for ground and power, if applicable.
Old 09-07-2009, 01:12 PM
dacrxguy's Avatar
well my auto 91 cluster had it but all i get when i look up the pins is d5-d1 no exact pin out is given but i will keep looking
Old 09-07-2009, 01:16 PM
dragvixen's Avatar
according to my diagrams it is the shift light ur right
Old 09-07-2009, 01:17 PM
dragvixen's Avatar
the pin on alldatapro.com says its pin d4
Old 09-07-2009, 01:22 PM
dacrxguy's Avatar
that orange wire that hooks up to the bolt its location is a "speed pulser"
Old 09-07-2009, 01:29 PM
dacrxguy's Avatar
here is the pinouts kind of hard to see
Old 09-07-2009, 05:40 PM
ketchup's Avatar
well I took a look at the wires on the plug and they are colored - GRN/yel - GRN - GRN/blk - RED - RED/blk
I'm guessing red = power and red/blk = ground
going to test it out with a voltmeter when the car is running again.
Old 09-07-2009, 05:51 PM
DCRB's Avatar
it's the factory shift up light for the crx hf...
Old 09-07-2009, 08:17 PM
punkdown's Avatar
I think that box has different uses depending on the cluster/car its from. On my CRX DX it's the speed sensor amplifier, on the LX/EX sedans it controls the cruise control indicator, and I guess judging from that service manual it control the HF's shift light. The red and red/blk are for the guage lights and are hooked up with the dash brightness control. If your car has green wires instead of yellow, you might find 12v on the GRN. I wouldn't use the red or red/blk for anything, you could burn out your dash light circuit.
Old 09-07-2009, 09:50 PM
ketchup's Avatar
Cool, I'll check out the grn wires then.
Old 09-10-2009, 05:08 PM
ketchup's Avatar
Looks like I MAY be able to make good use of it, thanks for the diagram.
Now does anyone know if the yel/red speed sensor wire goes to the ECU and if it is the same for electronic VSS?
according to that diagram, it mentions nothing about a shift light.
behindblueyez19
01-09-2008 02:39 PM
turbob18si
04-08-2007 04:43 AM
rewerbcrx
09-16-2005 07:07 PM
88civichbz6
01-26-2005 06:11 AM
Quick Reply: 5 pin blue gauge cluster plug
