3 questions
3 questions
1. Does anyone know how to adjust the clutch pedal height, becuase my friction point is too close to the driver, makes it difficult.
2. Also, my brakes, everytime i slow down at a lightor a stop sign, and i apply constant pressure, the pedal starts to sink. i check the main cylinder and if there were any leaks, coulndt find any.
3. Any one know how to remove headlights and corner lights?
Re: 3 questions (lx130)
1. What engine and tranny? Clutch cable or hydro? Is that for your truck or a CRX?
If its a CRX cable d15 like mine you adjust the clutch release point (looking at the engine from front) on the left side between engine and battery. There is an adjuster on the cable towards the end
2. Leak in brake line. Or MC is junk. (Prolly MC is junk)
3. ??? Never done it
1 Post
follow the cable towards the tranny, there is a mounting bracket down by the battery. You should see a nut on the cable pull up on the cable and give it a turn then try it. if more is needed repeat.
And it is your master cylinder, look just below it on the bottom of the brake booster.
Headlights I haven't done either.
mercury24
12
08-29-2013 07:05 AM
