**the official ef suspension thread**
#352
Re: **the official ef suspension thread**
im surprised 15 pages and only one person has progress....thats what im getting ...im running egay's that are frozen at stock height from last winter...i had to cut the struts off of the sleeves to change the rear struts last spring ...not to mention the springs are hella stiff and ride like sh*t
#354
Omni power full coilovers 12/10 set up, These are for an EG so they dont go as low as i would like so i couldnt get the stance i wanted. Also a lil rough on the roads but there great coilovers
#358
#360
#363
Suspension:
- Progress CSII 10 kg/mm front and 10kg/mm rear
- Si front and rear sway bars (stock)
- OEM brand new upper control arms and outer tie rods
Alignment:
Camber - F -3.2 R -1.8
Toe F +1 (something off with geometry after installing the DA knuckles. Maxed out Tie rod threads. Need to cut thread to correct toe). R +0.2
Brake:
- DA brake booster and MC
- DA integra front knuckle assembly w/ disk
- 4040 prop valve
- DA rear trailing arms w/ disk (not installed yet because of broken bolt head in trailing arm)
Comments:
Measurements from center of wheel to bottom of fender are around 11.5" front and rear. Progress recommends a ride height of 11.5" to 12.5" so i am in spec. I am impressed with the overall quality of the progress coilovers. The 10k front and rear give the car a more oversteering nature. The stiff rear rate makes bumps very rough and highway ride choppy. Overall i would recommend them to anyone. Im tracking the car next year and this was a great start up suspension set up with customizable rates.
Front Suspension assembled. Progress coilovers reuse the OEM top hat and OEM forks. The kit comes with upgraded poly bushings for the top hat.
The tire is about flush with the fender. Excuse the horrible body work. Planning on doing the exterior this spring. This year was engine swap, suspension, and brake year.
Parked out on the street.
Alignment:
Brake:
- 4040 prop valve
Comments:
#364
I actually find that my 500# rear springs aren't all that bad compared to other parts of my car. I'm not sure what 'highway speeds' are, but I regularly do 55-60 mph without any real decrease in comfort.
I had originally rated the 500# rear springs as harsher than they are because I was driving mainly through neighborhoods.
#365
The harshness is all relative based on what roads you are driving on. My car is also gutted, so there is literally no weight over the 10k rear rate. The roads here in Calgary are terrible because of our winters. Lots of filled cracks, huge bumps, and most bridges are deformed. So this is my experience. On brand new roads my car rides quite nicely. but overall I am experiencing a very choppy ride. Because race car.
#366
#367
Might as well use the official thread.. Anything new in the market for EF? I'm looking for a softer street setup. I'm slammed on Skunk2 coilovers from the previous owner, and they ride terribly. I want to keep close to stock height. Most searches bring back people looking for race coilovers or stiff sport. Even when 'street' is listed, it's vague. Looking for some insight.
lived dreams
07-09-2009 12:19 PM
