Honda CR-V & Element 2WD & 4WD Element & CR-V
CRV start problem
Old Jun 12, 2023 | 01:50 PM
rsorl's Avatar
Icon5 CRV start problem
2015 CRV, 56k miles, no other issues.
Won't always start on first push, sometimes takes three or four. In attached video it started on 2nd push.
Honda dealer mechanic tested alternator, starter and says they are fine.
Changed so far battery, push-key assembly, and key fob battery.
Any ideas?
File Type: mov
Old Jun 13, 2023 | 05:27 AM
starchland's Avatar
Default Re: CRV start problem
When issue occurs, can you still hear the starter relay clicking? Has the starter wire spade connector been checked ?
What is the green light on the button telling you?
Old Jun 13, 2023 | 03:54 PM
rsorl's Avatar
I don't really hear anything beyond what's on the video i attached previously.
Thanks for bringing this to my attention, i'll pass it along to the mechanic, i'm going back in this Thursday.
Not sure which green light to check? I haven't noticed anything out of the ordinary until just now, when i saw the "no key" error despite the key fob being on me, and with a fresh battery in it. Any chance this could be a key fob problem?
Old Jun 13, 2023 | 04:16 PM
starchland's Avatar
not sure what you are trying to show with the video. The light turns green assumably saying car is ‘ready to start’. Do you always get the green light prior to starting?
Possibly. Where are you keeping the fob? It is proximity based however I believe like Honda models of past, the fob can be dead and still start the car since the immobilizer chip in the key/fob does not require its own power (much like a tap credit card works)
Old Jun 13, 2023 | 04:35 PM
rsorl's Avatar
I don't always get the light prior to starting. I'm not showing the video as much as i am showing the sound.
For first 8 years of driving this vehicle, a single push would fully start the car. Now, it takes two (or sometimes even three or four), almost as if the battery is dead.
I keep the fob in my pocket always, but i can try my spare (that i never really used) and see if the problem continues.
Old Jun 14, 2023 | 05:28 AM
starchland's Avatar
check all wiring and grounds. A bad starter seems unlikely at said mileage but anything is possible. Potentially a bad starter? can mimic a bad battery in how it labors to start/turns over slowly.
Old Jun 14, 2023 | 01:53 PM
rsorl's Avatar
it's not the fob, i used the new one and just had the same problem.
i'll pass your suggestions to my mechanic tomorrow, thanks for your input.
Old Jun 23, 2023 | 09:12 PM
rsorl's Avatar
As it turned out, it was the starter after all.
Old Mar 28, 2024 | 05:57 AM
lmbillett's Avatar
rsorl....I'm having the same problem. So frustrating. I feel it's the push button as I've had everything else checked. Since you posted in June 2023 is it still working??? To clarify....When you say the "starter" do you mean inside the engine or the push button? Thanks.
Old Mar 28, 2024 | 07:30 AM
rsorl's Avatar
it was the starter under the hood. even though it tested fine, it eventually failed the test after mutiple repeats. replaced it, no issues since.
neoblasted
Honda Civic (2006 - 2015)
Dec 11, 2019 04:00 AM
beehonda04
Sep 22, 2010 04:35 PM
veilsides2000
Honda S2000
13
Apr 1, 2009 05:17 AM
mrcch
Sep 15, 2004 08:39 PM
Vinny Chase
Jun 23, 2003 02:56 PM
