2004 honda accord wont start, not battery problem
My 2004 honda accord started when i went to work, started when i went to lunch, wouldnt start when i got off work. I just put a new battery in 4 weeks ago. It wont start even when jumped. what the heck. It will be fine for days then just start messing up. Someone please give me some advice. We checked connections and got alternator and starter checked and they were fine.
Re: 2004 honda accord wont start, not battery problem
need a little more info. what does it do when you try to stat it? does it crank? does it click? how long has this problem been going on? when it does start...is it random or do you usually do something?
It has been doing this for about 2 months. I bought a new battery and it didnt do it for 3 weeks. It was random. one day would start later in the day it wouldnt, i would look under the hood and everything loooked fine, close the hood, try to start it agin and it would start. I killed the battery trying to start it last nite. charged it all nite. it had a full charge this morning and still wouldnt start. It tries to turn over then clicks.
hm def sounds like a battery problem. make sure that battery is the right size for your car that the connections are tight and that the cables aren't corroded inside the insulation. i know it must be frustrating but check battery circuit carefully.
amyshonda
01-10-2020 12:29 PM
Katie Stanley
08-01-2017 07:23 PM
New Year Wishes
10-10-2012 11:07 AM
mohmandem
07-04-2012 10:47 PM
andrew160
08-08-2008 01:18 PM
