ZC swap help?
ZC swap help?
i need help with my twin cam zc swap into a 2000 civic it cam out of a 95 civic i need help with wiring harness do they make converters or does any one know someone who mite have a harness
Seagull Management
Re: ZC swap help?
Nope, bolt pattern for the intake manifold is different. Bolt pattern for the exhaust is the same but the ports are shifted slightly to one side so if you use anything but a ZC exhaust manifold you should port match it. I sincerely hope that's an OBD1 ZC. You can make them work reasonably easy. OBD0 Models will require an OBD1 distributor which are notoriously difficult to find.
EJ1_samson
11-14-2009 08:33 AM
The Destroyer
11
12-30-2005 02:22 PM
