Z6 Rebuild cost?
Re: Z6 Rebuild cost? (redcxhatch)
What would a rebuild kit for a Z6 cost?
Bearings, gaskets, seals, rod bolts, ect ect ect.
if you go all honda...$280 for bearings, rings are $38/each...another $100 - $200 in other stuff. Then you need somebody to put it all together. It will normally cost around $1000 or so.
If you go aftermarket, it will cut the bill by about $300 - around $700.
You can buy a used Z6 shortblock for cheap tho...anywhere from free -> $750. My jdm ZC SOHC block $150 and its perfect and runs great.
liam
Re: Z6 Rebuild cost? (cjames235)
what kind of aftermarket parts are you talking about to save that much money? im looking everywhere i can to save money
liam
Re: Z6 Rebuild cost? (liam821)
Bottom End:
Rear Main Seal $12.20
Oil Pan Gasket $16.66
Oil Pump $105.19
Oil Strainer Gasket $1.31
Oil Jet Orifice (block surface) $5.41 (needed to convert z6 to a6 non vtec style. if staying vtec dont need it.)
Water Pump $47.57
Thermostat $11.01
Thermostat O-Ring $2.02
Water Pipe O-Ring $1.44 x 2
ACL Race Series Bearings (Main, Rods, Thrust) $103.00
ARP Rod Bolts $35.99
D16a1 Pistons $34.66 x 4 = 138.64
Piston Rings $21.32 x 4 = 85.28
dont forget hot tank, honing, and balancing(preference). variuous stuff like assembly lube, tools, etc etc.
hope that helps.
[Modified by JaeOne3345, 5:02 PM 2/1/2003]
Oil Pump $105.19
Water Pump $47.57
Thermostat $11.01
hope that helps.
Re: Z6 Rebuild cost? (lazy bum shaughn)
Looks pretty expensive, I'd just save for a B-series swap.
Re: Z6 Rebuild cost? (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense »</TD></TR><TR><TD CLASS="quote"><BLOCKQUOTE>quote:<HR>Lo oks pretty expensive, I'd just save for a B-series swap.<HR></BLOCKQUOTE>
Why? $1000-$1500 well spent dollars on a d16z6/y8 will put down more power than a b16a2. The d-series has a lot of potential. There is a guy named Bisimoto that runs a d15 (yes, a d15), doing 10.77 in the 1/4mi (naturally aspirated). Of course he has an insane amount of work done. My point is simply that you don't have to swap to get power.</TD></TR></TABLE>
your point is invalid because he probably spent way more than any b-series running the same numbers.
ANYWAY. rebuilding is best because you're basically starting with a brand new engine. you have the confidence knowing exactly what you're running and knowing the whole history of your motor
cityofcaterpillars
23
05-24-2016 08:03 PM
gnar kill
04-21-2005 08:24 PM
