z6 knock
z6 knock
I got a 93 civic ex that i bought without a motor. I put a used d16z6 in it and it ran and sounded great for a week. Now it has a low end knock. Its a automatic so you can hear it knock before the trans shifts gears. If you rev it up just a little you can hear it knock but it dont do it at higher rpm's. Does this still sound like a rod knock?
Re: z6 knock
Try pulling spark plug wires one at a time to narrow it to a cylinder. Don't rule out a loose or missing engine or accessory mounting bolt or other sources that can create a knock.
Re: z6 knock
Removing plug wires would help diagnose a miss, not a knock. It also risks frying the distributor. Not only would that test be diagnostically worthless, it might set the OP back a nice chunk of change for a replacement.
How about we don't do that.
OP, drain your oil and look for metal fragments. Buy or make your own motor steth, and narrow down the exact location of the noise.
Re: z6 knock
Momentarily pulling a single plug wire is not going to immediately roast your coil. The energy will dissipate to the next plug that fires. It is one of the oldest troubleshooting techniques around for diagnosing an engine knock (yes you can also identify misfires in this manner).
[626]95-GSR
08-21-2003 05:33 AM
[626]95-GSR
08-21-2003 02:34 AM
