Z6 HEAD SWAP PROBLEM
I JUST SWAPED A Z6 HEAD ON MY Z1 BLOCK FOR FUTURE BOOST PLANS. IVE DONE HEAD SWAPS B5 AND NEVER HAD A PROBLEM LIKE THIS. I GOT THE Z6 OFF A FRIEND THAT HAD A AUOT MATIC EX. BOLTED ON SMOTHLY AND STARTS. I HAVE ONE PROBLEM, THE IDLE JUMPS UP AND DOWN LIKE CRAZY. MIND U I STILL HAVE THE STOCK Z1 ECU IN IT.IVE CHECKED THE IDLE SCREW ON THE THROTLE BODDIE, CHECKED THE SPARK PLUGS AND WIRES, THOSE ARE ALL FINE. I JUST CANT FIND OUT WHAT THE HELL IS WRONG WITH IT AND WHY ITS DOING IT. CAN NE ONE HELP ME OUT!! THANKS
Re: Z6 HEAD SWAP PROBLEM (vxtirent08)
did you swap intake manis too? sounds like the fast idle thermo valve. it's right under the throttle body...you take like 2 screws off and screw it back in. run a search on "fitv adjustment" and see if that's the problem.
it's down a few posts....
https://honda-tech.com/zerothread?id=284207
look at the #13 box...that's the fitv. #2 is the gasket for the cap you need to take off...once you take the cap off, you'll see a white bulb thing with a slash in it. turn the white bulp in like a screw until it's somewhat tight (don't crank it on...just turn it until it stops.
there is coolant in there, so watch out.
Re: Z6 HEAD SWAP PROBLEM (SOHCejcivic)
ok i did all this, and its working fine, now i got a check engine light on. how do i check what code it is? i heard something about changing the o2 sensor when swaping the head. could that be the problem?
