y8 intake manifold layout
Guest
Posts: n/a
Re: y8 intake manifold layout (menkio)
also, i have a b16a3 tb on the way, what about thye map sensor and crap.. with is an auto y8 intake manifold, on an auto car, 99 dx. i read the arrical off spades d topic, but im unsure what to do with a B series tb on a auot y7/y8 conversion
Im sort of helping this dude do the swap by providing some tech info over the internet. So far, i've determined that the B16 TB will bolt directly on, the MAP sensor and TPS will plug directly up. I've pretty much found out about all the coolant lines/vacuum lines and such, but the thing that has me is the IAC (Idle Air Control). on the y7 it has 3 wires, while the y8 has 2.
Now looking at an OBD2 pinout, i see that pins A12, A13, A14 are sensor signal, negative, and positive respectively. How would the y8 only have 2 wires if the ECU requires the 3 wires?
this is the main problem....
puertoricanboy90
66
01-15-2011 06:31 PM
ITSTOCK
09-18-2003 07:58 PM
MrTodd
08-01-2002 10:07 PM
