Y8 closed throttle idling problem
Okay my problem is that when you let off the gas the rpms drop down very low like about 200-300 rpms and the car will stall.
I have verified the timing, adjusted the idling and still get stalling.
Even sitting stationary handbrake up with no load, light on, or fan just by blipping on the gas you can see it goes up to 3000-4000 rpms no problem but when it comes down the rpms drop to 200-300 rpms.
sometimes it will not stall but most of the time it will.
I have cleaned the IACV, there is no FITV, cleaned the throttle, check for vacuum leaks, no CEL, and still do not know what is causing this.
I do not have another ECU to test.
civicEX1995
10-26-2012 03:46 PM
suspendedHatch
06-04-2005 02:25 PM
