y7/y8 rev problem
y7/y8 rev problem
aiight i got a 96ex with a y7/y8 mini me i just finished......i got all the sensors back on the vavs are all hooked up and all that....
so i go and start the car and it REVS way HIGH.....like 6k............
so i disconnect the throttle cable and it still does the same thing
just need some info on what i should check and if u have had the problem before and know what it is it would be greatly appreciated...ty for the help in advance
Re: y7/y8 rev problem
ok that was never messed with during the process of the swap.....i was told it might be the TPS and taking it off and using carb cleaner might help....i will get at it again tommorrow im tired...
^To test this, pull off intake, turn car on and cup the TB hole with your hand.
If it dies, no vac leak, if it DOESN'T DIE, it's being sustained by a vacuum leak.
yeah throttle plate its rotating like it should and flipping back like it should....ive not tried the leak test so imma have to do that.......well in the morning.....as well as take the TPS off if it turns out to be that
TurboGoKart
09-30-2009 02:53 PM
_HANS
16
05-17-2006 01:21 PM
Ricey McRicerton
08-10-2003 04:17 PM
