Y8 bogs
Y8 bogs
So my car bogs around 2k-3k rpm when it is warned up or drive for a while. I've changed spark plugs and even my distributor o-ring cause it was leaking. Could it be some fuel problems or is it some wiring problems? I did google research and they only give generals. Any one know any specific?
Update!!: so when If I clearly let go of gas first then shift my car runs fine but if I do like a quick shift where throttle has just stopped then shift car bogs from 2k-2.5k rpm. Similar to anyone's problem?
Re: Y8 bogs
I had the same problem with my 93 del sol si D16z6. After the tuneup it still wasn't right so I replaced my throttle position sensor (TPS). Had the original one in there I figured after 21 years it might need to be changed .
There's a good write up on it. If I find it I'll link it.
Re: Y8 bogs
I see. So pretty much change the whole distributor? With wires? Would fuel injectors be some sort of problems too?
Re: Y8 bogs
Re: Y8 bogs
Can the o2 sensor be the cause of it too? Or would it need to throw a CEL?
rotascircuit
03-22-2008 11:29 PM
ApolloSpeed
14
08-19-2005 09:12 AM
