Would these springs fit?
Old 03-01-2010, 02:43 PM
rugimpy's Avatar
Default Would these springs fit?
I have a 93 coupe and some guy is trying to sell me a set of H&R Sports for a 96-00 civic. He says they will fit and will sit the same but I wanted to see what you all thought. Thanks all!
Old 03-01-2010, 02:44 PM
Master Detailer
98civdx's Avatar
Default Re: Would these springs fit?
yea they will fit.
Old 03-01-2010, 03:16 PM
rugimpy's Avatar
Have you tried them? Do they sit the same? Cause they have different part numbers on the H&R website.
Old 03-01-2010, 06:32 PM
Master Detailer
98civdx's Avatar
i have not with h&r but i have with integra springs.
Old 03-01-2010, 09:20 PM
rugimpy's Avatar
Yea, but dc's and ej1's are more interchangeable than the 96-00 civics. Im worried they wouldnt work. I want someone that has done this. Please!
Old 03-01-2010, 09:57 PM
Kilovdro417's Avatar
The only thing thats different about 92-95 suspension and 96-00 suspention is where the rear struts mount to the lower control arms. So I would say there definity gona fit
Old 03-01-2010, 10:00 PM
batallic's Avatar
they will fit i have 96-00 full coilovers, on my 93 ex, i did have to trim the bushing for the rear shocks to work BTW
Old 03-01-2010, 10:01 PM
rugimpy's Avatar
So im going to have to trim the bushings is what you are saying?
Old 03-02-2010, 10:48 AM
Master Detailer
98civdx's Avatar
^^ NO, only if you use ek shocks, becuase the eg lca is a little widder then the 96-00 shock, like i said they will fit just fine.
Old 03-02-2010, 12:14 PM
batallic's Avatar
Old 03-02-2010, 02:31 PM
EBPcivic2000's Avatar
i say use what they say to use for your car. if it doesnt say 92 to 95 or 92-00 i wouldnt use it.
Old 03-02-2010, 03:23 PM
rugimpy's Avatar
Yea, see im paying to have these shipped and I may not be able to get a refund if they dont fit, so I am hesitant if I dont know for sure. I almost feel I should just use whats for my car as well.
Old 03-02-2010, 04:26 PM
batallic's Avatar
they will fit, but if yur hesistant then dont use it
Old 03-02-2010, 04:40 PM
freeagent's Avatar
thats like saying i wouldnt use a b series because its not meant to be in my 92 dx.....
Old 03-02-2010, 04:54 PM
iamthefollower's Avatar
x2, they will fit, but if you are terribly worried, just don't buy em.
Old 03-02-2010, 06:52 PM
Master Detailer
98civdx's Avatar
then dont buy them
Old 03-03-2010, 07:21 PM
rugimpy's Avatar
Sorry to bring this back up, but I have another question. The springs may fit fine, but what about the difference in spring rates? Are the weights going to make the springs sit higher? Thanks.
Old 03-03-2010, 07:54 PM
Bender C/F's Avatar
They are lowering springs arent they? Just to warn you, if they arent adjustable your ride is going to be rock hard, no bounce. Also, as long as they arent custom springs, all springs (not struts) from 88-2000 are compatible with eachother. The springs themselves are totally interchangeable. Struts however, are unique to their generation. (ex. 88-91, 92-95, 96-00)
But in terms of buying online, If you aren't 100% comfortable with buying the product, i would look for something else. Someone could just be trying to pawn something off on you.
Old 03-03-2010, 08:06 PM
Master Detailer
98civdx's Avatar
yes there is a difference, it could ether make it sit a bit higher or lower.
also Bender C/F how do you know it will be rock hard?? just wondering
Old 03-03-2010, 08:30 PM
Bender C/F's Avatar
i swapped my stock springs for non-adjustable lowering springs on my 91 CRX Si.
The ride looked sick, but cracks and bumps in the road were brutal. The suspension might as well have been welded solid.
Old 03-03-2010, 08:39 PM
rugimpy's Avatar
Ok, thanks guys. I appreciate the help.
ej1252
Suspension & Brakes
08-09-2010 01:35 PM
LittleG112
02-08-2005 05:47 AM
jimmhatch
09-13-2003 05:17 AM
b00stn
01-26-2003 07:42 PM
flipkid
10-03-2002 08:24 PM
Quick Reply: Would these springs fit?
