Wiring Problems LS In 98 civic DX
As it say's I have a 98 LS engine in my 98 civic dx coupe and I know I need to switch over the 3 wire to a 2 wire on the Idle Air Control switch on the throttle body but don't know which on the civic side will wire up to the integra plug trying to make this motor bar'd in the car so if you know please let me know. Thanks
Re: Wiring Problems LS In 98 civic DX (crxd88)
Well, your question is pretty confusing. Are you asking which 2 of the 3 wires you use? Also, you have to pull one wire completely out at the ECU then move another. Do a search for 3 wire iacv and you should find your answer. There are tons of answers to this question; you just need to type a few words in the search engine...
Re: Wiring Problems LS In 98 civic DX (RyanA)
On my car there is 3 wires for IACV but on the integra there is only 2 thats what i was trying to type but didn't so thanks but more info would be appreciated. Also if you know which 2 wires that would be appreciated and which on the harness needs to be changed if you know? Thanks
http://www.ff-squad.com/tech/w...8.jpg
check that link..
http://www.ff-squad.com/technet/
also that link.. it has a lot of info for wiring swaps into civics.
check that link..
