Wiring problem PLEASE help guys!!!
HEY GUYS 3 PROBLEMS!!
in my ek i think i have a bad ground or something........when the passenger door is open, the window works, when its closed it doesnt...its power windows
and when the door is closed, the front passenger speaker doesnt work...but when its open it does.....
my indiglo, i didnt want it , it came with the car but...it keeps going from bright to dim to off....in a pattern....i checked and fixed all connections....still does it...what can i do?!!
what should i do!!!
what should i do!!!
Electrician
1. Remove door panel and check harnesses attached to your door for your windows and locks. Look for any "stripped" wires touching anything metal.
2. While door panel is removed, check speaker wires or harness (if stock speakers are on) for any "stripped" wires again.
3. Remove gay *** indiglos and call it even.
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">1. Remove door panel and check harnesses attached to your door for your windows and locks. Look for any "stripped" wires touching anything metal.
3. Remove gay *** indiglos and call it even.</TD></TR></TABLE>
W3RD!
W3RD!
