Window Help
Old Jun 21, 2003 | 05:59 PM
GeorgeY's Avatar
Default Window Help
Today I decided to fix the rubber piece that connects to the guiding rails in the window. So i took off my door and reattached the piece. While the door was off i decided to tighten all the screws for my speakers. I had disconnect the power window and door locks to take the door off. After i put the door on, my passenger side window will not open. I checked the fuses and the 20A fuse keeps blowing. Do you guys have any suggestions? I have no more warranty as i have 54000 miles. THanks
George
Old Jun 21, 2003 | 06:37 PM
Eric R's Avatar
Default Re: Window Help (GeorgeY)
Seems like the wires are shorted out or the window motor has a short and is blowing the fuse.
Old Jun 21, 2003 | 06:45 PM
GettaluvR's Avatar
New User
open ur panel again and check all the wires inside, see if there is any wire that is broken, if so use electrico tape wrap it
Old Jun 21, 2003 | 07:01 PM
g5r's Avatar
g5r
Default Re: Window Help (GettaluvR)
yea check all your wiring.
Joey Mitchell
Apr 13, 2019 11:58 AM
eg6sir88
Mar 24, 2010 06:25 PM
SCushman
May 23, 2008 08:51 PM
Rayz_Si
Apr 21, 2008 06:17 PM
