wiring help!!!
wiring help!!!
Ok, first off im putting a 95 d16z6 into my 97 civic dx, i know i have to convert from the 3-wire IACV plug to the 2-wire IACV plug (already did that) and i have to move the A14 wire on the ecu plug to the empty A12 slot, and discard the A13 wire.
heres what im workin with...
I tried just pulling out the A13 wire before i went and ripped out the A14 wire, lucky for me, because i cant seem to get the wire out. I ended up just cutting the A13 wire and i wanted to ask someone how exactly i can pull the A14 wire out without cutting or ripping it out.
Thanks
Thanks
Re: wiring help!!!
you will have to de-pin it. you will take a small pick or some time a screw driver will fit the best is to take the metal piece out of a windsheild wiper and take it to a grinder to make it a little smalled and you will push it in the back of the connector and push up a little tab on the connector and the wire will come right out. just be careful because you can brake the tabs off if your too forceful
Re: wiring help!!!
ok so that "tool" idea didnt work for me. broke the tool i had off inside the plug so i just ripped the wire out. bought a pack of 20-18 gauge female gm 150 metripack terminals, MTM part number is 85335. they seem to be too big to fit in there but that was the smallest size pep boys carried and of course they have no catalogs or anything so they cant look up anything and the parts store i work at is closed until monday.
can anyone help? by the looks of it im gonna have a CEL problem when i go to put this motor in
Re: wiring help!!!
Hope that helps....
Re: wiring help!!!
yeah i couldnt get it, and i quit while im ahead before i break anything else im just gonna take it somewhere and let it be someone elses problem. i love doin the work myself on my own car but not when i keep breakin ****...
turbob18si
12-16-2011 05:00 AM
