WINDOW POPPING OUT
WINDOW POPPING OUT
hey guys im sure many of u have encountered this...wen the thieves try to break into ur car and [freak] up ur window.....meaning wen u roll it up it pops out and doesnt go up like it is supposed to ...does any1 know what i have to change or fix to fix the problem?? let me know because i hate having to hold the window so it will go up right!!
Re: WINDOW POPPING OUT (Nino_eg6)
What's happening is your window keeps coming off track.. What u need 2 do is take off the door panel.. 1 screw behind the door handle.. 1 screw next to the windows switch or way ever its called.. And 3 around the door speaker.. Make sure u disconnect the wire harness for the power locks and window and speaker..Once u got the door panel off.. Take off that paper thingy.. Then at the bottom of your door you should see a bolt on each side that's holding your tracks for the windows.. unscrew the bolt that the window came off of.. Put the window back on track.. Plug in the power window harness.. And play with the window a lil bit.. To make sure it won't pop off again.. Screw in the bolt u unscrewed then bamm your done.. Put everything back once your done if u want..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nino_eg6 »</TD></TR><TR><TD CLASS="quote">thnkz dude i dont have power windows but im gona follow ur basic steps </TD></TR></TABLE>
This is a common thing for civics. If you want to avoid doing this every couple of months take the time to spray the tracks with some silicone spray while you have everything apart. You can pick up a can at your local autoparts store. This will help the window stay on track and make it smoother.
you also may want to look into getting a new window gasket or whatever the hell its called, the whole rubber pieces that holds the window in place and seals out the weather, for my EM1 it was $65, hondas are infamous for this problem, ive had to do it on every honda ive owned
Tomas P
04-06-2012 12:06 AM
Rayz_Si
04-21-2008 06:17 PM
JamesV
06-21-2006 04:07 PM
RATEDR
05-23-2002 06:39 AM
