will this short shifter fit?
Old 02-16-2009, 09:54 PM
mynameizstitch's Avatar
Default will this short shifter fit?
ok i will be ordering a fidanza short shifter. my car is a 93 civic hatchback with a b16a3 swap. i was wondering if this one would be ok since i have a b16a3 swap and was concern since the shifter and shift linkage may be a lil different. it states that it will fit 88-2000 civics.
here is the link to the short shifter i want to order.
http://www.autoaccessoriesgarage.com...ID=1003&vlink=
Old 02-16-2009, 10:13 PM
Master Detailer
98civdx's Avatar
Default Re: will this short shifter fit?
it will NOT fit.
your going to need a shifter for b series, that is a d
Old 02-16-2009, 10:43 PM
so any b series shifter should fit? like the ones made for integras or 99-00 civic si?
Old 02-16-2009, 11:21 PM
ixoiiiiviviiivi's Avatar
Any d series shifter will fit and so will the b16 shifters. integra (b18) shifters will not fit unless you modify the shift linkage. (they tend to be about half an inch wider and will not fit in the fork of the shift linkage)
Old 02-17-2009, 05:36 AM
ok so im confused now one person said any d series shifter will fit or a b16 shifter. i just want to confirm is that true?
Old 02-17-2009, 05:44 AM
delsolsi193's Avatar
you need a b-series shifter for a b-series tranny.
Old 02-17-2009, 07:09 AM
hmoobhero's Avatar
yup, but never tried using d series shifter on b series shift linkage. mite work. try it and let us know.
Old 02-17-2009, 10:49 AM
Master Detailer
98civdx's Avatar
just get like a 99-00 si shifter and put it in,
i have never tired an itegra shifter but i have been told they dont fit.
Old 02-18-2009, 01:59 PM
Depending on the shift linkage you have put in. If you have a B16 Shift linkage ANY D SERIES or B16 shifter will fit. Integra (b17/18) shifters WILL NOT FIT. Doesnt matter even if theyre B series. They will only fit if you have a B18 Shift linkage. The only way to get the b18 integra shifters to fit is to grind them down about 1/2 and inch. the b16 shifters will fit in the b18 linkages with spacers to fill in the gap. the fork size is narrower on b16 shift linkages. look up the differences if you dont take my word for it.
Old 02-18-2009, 02:11 PM
bigBOI_92DA9's Avatar
To be on a safe side get a shifter for 99-00 civic SI.
Soon 2BE
Honda Civic (2006 - 2015)
05-18-2012 11:09 AM
thanh4o8
01-05-2009 05:08 AM
jdmhatch1
13
04-19-2008 10:05 AM
THEDirtyDseriesWOOT
04-26-2007 08:56 PM
ichibano
04-05-2003 04:31 PM
Quick Reply: will this short shifter fit?
