Will my motor be ok?!?
Re: Will my motor be ok?!? (vc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vc »</TD></TR><TR><TD CLASS="quote">
Its my first time. damn that was the longest 15secs of my life.</TD></TR></TABLE>
15 secs?
15 secs?
Re: Will my motor be ok?!? (Chong)
15seconds?..you mean the entire situation with your downshift..or 15 seconds of worrying after you did it?.cause if you had a led foot for 15 seconds with the gas pedal down and the rpms to 9000...then you must have a horrible reaction time and shouldnt be driving in the first place..people will flame..so edit your shiznit or clarify your post..
Farts in the shower
Should be ok. But a suggestion since you have a p28, why don't you set fuel cut off/redline to a specified level so you don't do it again .
ahh itll be fine!!! if my d16y7 can be ragged out to 7500 rpms your b18 will make it LOL....d16 is 2 inchex from death but still running strong!!!
Re: Will my motor be ok?!? (Eaglekper0046)
The general rule is that if it didn't already go pop right there and then... you'll be alright. The standard valvetrain in my experience can easily withstand 9000rpm every so often.
Re: Will my motor be ok?!? (b18civicguy)
I went from about 70 in 5th to 2nd insted of 4th trying to pass, i floored it and felt like i hit the brakes insted of the gas, the tach pegged, no problems with it.
Re: Will my motor be ok?!? (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">If your motor still runs, your fine.</TD></TR></TABLE>
Yup, the main risk of doing that is floating a valve, you'll know immediately if that happens.
Re: Will my motor be ok?!? (O16581724 5 2 5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 »</TD></TR><TR><TD CLASS="quote">I went from about 70 in 5th to 2nd insted of 4th trying to pass, i floored it and felt like i hit the brakes insted of the gas, the tach pegged, no problems with it.</TD></TR></TABLE>
holy ****...i bet that got your heart beating.
Imperious: Mod of Valor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chong »</TD></TR><TR><TD CLASS="quote">Does it seem any different than it used to be? Im pretty sure the GSR can handle 9k once in a blue moon.</TD></TR></TABLE>
Exactly, it should be able to handle it if you don't beat on it daily. As long as you drive it well and keep it well maintained, you should be fine. Does anything sound/feel/drive different?
Psshht, my friend was shiftin from 3rd gear at 8k and mis0shifted to 2nd, it went waaaaayyyyy past the 9500 rpm where teh red stops. Probably 11k or more. His motor is fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 »</TD></TR><TR><TD CLASS="quote">I went from about 70 in 5th to 2nd insted of 4th trying to pass, i floored it and felt like i hit the brakes insted of the gas, the tach pegged, no problems with it.</TD></TR></TABLE> He was talking about this guy lol...still runnin good?
Re: Will my motor be ok?!? (.ken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken »</TD></TR><TR><TD CLASS="quote">Should be ok. But a suggestion since you have a p28, why don't you set fuel cut off/redline to a specified level so you don't do it again .</TD></TR></TABLE>
this is called a mechanical overrev.
there is NO protection against it.
the wheels are driving the engine. not the throttle.
