Will ek brakes fit an eg?
I have a 95 eg(dx) coupe and need some pads and rotors. Anyways My buddy crashed his 97 civic(ex). I wanted to know if i can use the entire front suspension minus the struts and springs.
So can i use the upper ball joint, spindles, calipers, and lower control arms and run the front sway bar? I wanted to use the front brakes cause i heard that the Si/EX brakes are bigger than the stock ones that my car came with. And the lower control arm cause obviously the sway bar. So will these fit?
Re: Will ek brakes fit an eg? (90_civic_Si)
you can use the EK spindles/knuckles with caliper and rotors without any issues.
Unfortuantly upper control arms are different, lower LCAs are also NOT a bolt on, unless you feel like swaping a complete crossmember along with steering rack and rear mount to EK spec.
Re: Will ek brakes fit an eg? (eg6ajk)
I`ll pass on that swap, i didn`t think it would work. So as far as the brakes are they biggier or just go with the stock pads and rotors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_civic_Si »</TD></TR><TR><TD CLASS="quote">I`ll pass on that swap, i didn`t think it would work. So as far as the brakes are they biggier or just go with the stock pads and rotors?</TD></TR></TABLE>
EX rotors = 10.25"
DX rotors = 9.5"
yes they are bigger
EX rotors = 10.25"
DX rotors = 9.5"
yes they are bigger
Orientalbigboi
09-08-2007 11:22 AM
endlesswinterco
12
11-07-2003 05:43 AM
