Will EK rear disc hardware fit an EG hatch
Re: Will EK rear disc hardware fit an EG hatch (RidinlowHatch)
Don't think it's a direct bolt on but I'm sure you could make it work. Just get rear trailing arms off a 92-95 ex/si or 94-00 tegs.
Re: Will EK rear disc hardware fit an EG hatch (Kalokohan)
ek and integra have the same trailing arms, so anything with rear discs will work. only thing u cant use is the ek LCA.
Re: Will EK rear disc hardware fit an EG hatch (chameleon)
EG and integra have the same rear trailing arms. As I understand it, EK are slightly different. However the EK trailing arms should work on the EG. I believe that you need to keep your stock lcas, compensator arms, and upper control arms. Also get the e-brake cables from the 92-95SI.
However if you don't already have the big front brakes (ex/si/gsr), then I would recommend that you upgrade those first.
Re: (RidinlowHatch)
Got mine from a salvage yard for $275. I replaced rotors and pads. Everything else was good. That didn't include master cylinder or brake booster, but I didn't need them since I have an EX.
Re: (kommon_sense)
i work at a midas so i can get all the brake compents themselves cheap. i just need to find the hardware. so u guys are saying that i need to upgraded a bigger master cyclinder? will the si work?
Re: (RidinlowHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinlowHatch »</TD></TR><TR><TD CLASS="quote">. so u guys are saying that i need to upgraded a bigger master cyclinder? </TD></TR></TABLE>
Definitely!
Definitely!
Re: (RidinlowHatch)
you don't really need a larger booster/master cylinder if you aren't upgrading the fronts. although, you should look into getting a proportioning valve for rear discs.
Re: (*******)
ek and eg trailing arms are the same, just the lower control arm.
also when swapping to rear disks, its a good idea to swap the proportion valve too.
90-93 has a 4040 prop
92-95 civic (w/rer disk)
del sol si/vtec
integra 94+
just to name a few...
brake master cylinder would also be a good idea to upgrade. you DONT HAVE to upgrade brake booster.... just get a larger brake master cylinder that would fit your stock booster. but as simple and painless as it is, the brake booster definately helped my car....
del sol si/vtec
integra 94+
Re: (Kalokohan)
HUM...
my friend has an ex civic (ek) and his master cylinder is 7/8. same as civic si isnt it? i think honda mix and matches sometimes.....
who knows.... pay no attention to my post then
BrianFreels
05-04-2009 01:36 PM
Prevail
09-26-2002 09:39 PM
