will a d16y7 engine be ok to replace my d16y5
my engine blew in my 97 hx. i need to find an engine this week for it the engine code on my motor is a d16y5 and it seems the y7 is more common to find. does anyone know the differences in these motors? any help would be appreciated. i know itll bolt up the same, but as far as any sensors being in different locations or missing etc. thanks
Shaun
Shaun
Re: will a d16y7 engine be ok to replace my d16y5 (nvmyb20hatch)
well you are going to have less power, not as good gas milage, and a non-vtec motor, the y5 was suposed to be a economical vtec motor, with only one intake valves opening before vtec, and both opening up after,
If i were you, i would try to get your hands on a d16y8 out of an EX, it has the most power from the D series engines from stock, if you have the money you might as well swap out a B series, if your on a budget, go with a B16 or a LS B18, you will be alot happier and both of those engines will have a lot more potential than the d series ever will with out a good amount of money
tico
07-10-2006 05:51 PM
keepitjdm
12-28-2004 09:00 PM
