Will a 99 gsr strut bar fit an eg?
I went outside just now to see if the holes are there on my hatch, but honestly it's too dark and I can't remember exactly where the holes should be. Also don't breathe down my neck please I did search.
Re: Will a 99 gsr strut bar fit an eg? (THEINTEGRATION)
That's good enough, thanks =]. I was pretty confident it would, just don't have it with me. I was trying to tell my buddy that the 94-01 integra and 92-95 civic chassis are nearly the same (at least the front half), he kept telling me the teg's engine bay is bigger...
Re: Will a 99 gsr strut bar fit an eg? (eastbay92cx)
it sure does the strut bars for newe r si and gsr are all the same as the old eg and dc2 bars you should have no prob...peace.
ok i got a gsr strut and when i tried to fit it on i found out that i had to do it so the bar was front and the extention of the end links were toward the windshield like the first pic with the itr. then in the second its reversed. does it matter cuz i cant do mine like the second one. the bolt that comes out of the shock assembly is sitting too hight..... did i do something wrong when i was messing with my shocks?
Re: (degooser)
I just put one on my hatch also.........5min. easy install. Popped off the rubber caps, jacked up the car and put up the four bolts. Doesn't get any easier than that.
Re: (t0ekn3e)
good question i was about to ask the same thing. width? length? grade? does it make a difference? also should i use locking nuts or just go with regular?
Re: (1C9R9X3)
i've read all the threads i could find in a search, and no one has specified the length or width of the bolts/nuts they used to install this bar.
I went to a local hardware store, and they couldn't find a correct bolt size, 12mm was too large, 10mm was too small. Didn't have an 11mm. What size should be used?
Re: (AmginE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AmginE »</TD></TR><TR><TD CLASS="quote">i've read all the threads i could find in a search, and no one has specified the length or width of the bolts/nuts they used to install this bar.
I went to a local hardware store, and they couldn't find a correct bolt size, 12mm was too large, 10mm was too small. Didn't have an 11mm. What size should be used?</TD></TR></TABLE>
umm sounds like 10mm will work with some washers...
New User
the bar is on backwards.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEINTEGRATION »</TD></TR><TR><TD CLASS="quote">Sorry on the late follow up. I found pictures with the strut. It's looks a bit bent, but it's actually not.
JCracer723
06-18-2003 10:58 PM
B96v6
12-27-2002 03:20 PM
