vtec indicator light
Re: vtec indicator light (ARIZONA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARIZONA »</TD></TR><TR><TD CLASS="quote"> http://www.baustnet.com/honda/mods/vtec/vtec.htm
There ya go.</TD></TR></TABLE>
Good writeup, complete with pics.
Thanks a lot.
Thanks a lot.
Risky Business
Re: (TwistedSI)
Here's another:
http://home.earthlink.net/~civ....html
And here's a vid of my VTEC light in action (i'm a ricer):
http://www.we-todd-did-racing....D.jpg
Re: (BauleyCivic)
i thought u had to use some soart of resistor in the line to prevent pulling to much power from the ecu and causeing vtec not to engauge??
i like idea 1 but with the LED id rather not run all those wires through my firewall for one little light. way to much work. IMO
Re: (bmcc72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmcc72 »</TD></TR><TR><TD CLASS="quote">i thought u had to use some soart of resistor in the line to prevent pulling to much power from the ecu and causeing vtec not to engauge??
i like idea 1 but with the LED id rather not run all those wires through my firewall for one little light. way to much work. IMO</TD></TR></TABLE>
You're probably thinking of the resistor inline with the ground wire to prevent the LED from going out. And I'm splicing off the solenoid and running through the firewall. Very easy to do. I just used the big *** grommet on the driver's side. There's also one on the passenger's side. Here are the instructions I used: http://www.hazone.com/hvlight.htm
Risky Business
Re: (shaun311)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kKdARIAN »</TD></TR><TR><TD CLASS="quote">dont mean to jack your thread but i love the red lighting behind the dash in your civic BauleyCivic.. nvr seen that before'</TD></TR></TABLE>
And it just so happens I have a writeup for j00 https://honda-tech.com/zerothread?id=661308
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmcc72 »</TD></TR><TR><TD CLASS="quote">did u use the line for the silinoid or the pressure switch? also did u use any resistors?</TD></TR></TABLE>
Solenoid...pin a4. Think about it the pressure switch always has current going through it because its always monitoring the oil pressure. The solenoid wire gets a current only when VTEC is activated. And no, I don't have any resistors.
